StarTech.com 15 ft DVI-D Dual Link Monitor Extension Cable - M/F
£14.64
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Guaranteed reliability
  • Molded connectors with strain relief maintain a durable connection, helping to prevent damage to the connectors, for long term, error-free DVI to DVI video performance
  • Type: DVI
  • Length: 4.6m
  • Stock Status: In Stock
Product codes
Extend the connection distance between your DVI-D digital devices by 15ft. The DVIDDMF15 15ft DVI-D Dual Link Extension Cable allows you to extend the connection between your desktop workstation and DVI monitor, or your laptop and projector by up to 15-feet.
The dual link cable supports resolutions of up to 2560x1600 and transmission rates of up to 9.9 Gbits/sec, and is fully compliant with DVI DDWG standards.
This durable DVI male to female cable is designed to provide a high quality digital video experience.
Product Description StarTech.com 15 ft DVI-D Dual Link Monitor Extension Cable - M/F - DVI extension cable - 4.6 m
Type DVI extension cable - dual link
Length 4.6 m
Connector DVI-D - male
Connector (Second End) DVI-D - female
Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 15 ft DVI...
£14.64
