StarTech.com 15 ft Mini DisplayPort to VGA Adapter Converter...
StarTech.com 15 ft Mini DisplayPort to VGA Adapter Converter Cable – mDP to VGA 1920x1200 - White
£29.86
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Connect a Mini DisplayPort source directly to a VGA display or projector, with no additonal adapters or cables
  • Save upgrade costs by connecting your new Mini DisplayPort computer to a VGA monitor or Projector
  • Well-suited for Mac computers, with stylish white design
  • Suitable for longer distance connections, with 15 foot cable
  • Stock Status: In Stock
Product codes
Connect a Mini DisplayPort-equipped PC or Mac to a VGA monitor/projector, with a 15ft long white cable. The MDP2VGAMM15W active Mini DisplayPort to VGA converter cable lets you connect your Mini DisplayPort-equipped desktop or laptop directly to a VGA monitor or projector at a longer distance than a standard-length cable would support, while saving the expense of additional adapters. The cable features a stylish white design, that is well-suited for connecting Mac computers.
Plus, because the converter cable supports video resolutions up to 1920x1200 you can convert a DisplayPort video source to VGA without sacrificing video quality.
Product Description StarTech.com 15ft Mini DisplayPort to VGA Adapter Cable mDP to VGA - White - video converter - white
Device Type Video converter
Max Resolution 1920 x 1200
Interfaces 1 x DisplayPort output - Mini DisplayPort , 1 x VGA input - 15 pin HD D-Sub (HD-15)
Enclosure Colour White
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 15 ft Min...
£29.86
