StarTech.com 15 ft Monitor VGA Cable - HD15 MM
£6.03
Select:
Delivery:
Standard: 1-3 working days
  • Length: 4.6m
  • Stock Status: In Stock
Product codes
Attach a PC VGA port to a switchbox. This 15-foot VGA Video Monitor Cable features two HDDB15 (male) connectors, providing a high quality VGA connection.
The cable supports a maximum video resolution of up to 800x600. For applications that require higher resolutions, see 15ft Coax VGA Cable (MXT105MMHQ).
Product Description StarTech.com 15 ft Monitor VGA Cable - HD15 MM - VGA cable - 4.6 m
Type VGA cable
Technology Shielded
Length 4.6 m
Connector HD-15 (VGA) - male
Connector (Second End) HD-15 (VGA) - male
Compliant Standards RoHS
Colour Grey
Designed For P/N: DP2VGA3, HD2VGAE2, HD2VGAMICRO, MCHD2VGAE2, MDP2VGA2, MNHD2VGAE2, USB32VGAEH3, USB32VGAPRO
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 15 ft Mon...
£6.03
