StarTech.com 15 ft Thin Toslink Digital Optical SPDIF Audio C...
StarTech.com 15 ft Thin Toslink Digital Optical SPDIF Audio Cable
£5.37
Select:
Hurry, only 2 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Guaranteed reliability
  • Ideal for audio installations where space is tight or limited
  • Rich, detailed, optical digital sound, even at extreme volumes
  • Length: 4.6m
  • Stock Status: In Stock
Product codes
The THINTOS15 15 ft Toslink Optical Digital Audio Cable provides clean, accurate sound, with no distortion or signal interference.
The thin construction of this Optical SPDIF cable is perfect for installations in tight spaces. The cable features a polished lens, which helps ensure a reliable signal and high-level digital sound quality.
This 15ft Optical Audio Cable is constructed for maximum durability, for dependable, long-lasting connections.
Product Description StarTech.com 15 ft Thin Toslink Digital Optical SPDIF Audio Cable - 15ft / 15 Feet Optical Audio Cable (THINTOS15) - digital audio cable (optical) - SPDIF - 4.6 m
Cable Digital audio cable (optical) - SPDIF
Technology Fibre optic
Length 4.6 m
Colour Black
Connector TOSLINK - male
Connector (Second End) TOSLINK - male
Designed For P/N: BT2A, FLATPNLCEIL, FLATPNLWALL, FPCEILPTBLP, FPCEILPTBSP, FPWARTB1M, FPWARTB2, FPWFXBAT, FPWTLTBAT, HD202A, PEXSOUND7CH, STNDMTV70, VGA2HDPRO2, WIFI2HDVGA
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 15 ft Thi...
£5.37
