StarTech.com 15 m Cat5e Gray Snagless RJ45 UTP Cat 5e Patch C...
StarTech.com 15 m Cat5e Gray Snagless RJ45 UTP Cat 5e Patch Cable
£9.60
22 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Les connecteurs en or +á 50 microns optimisent la conductivit+® tout en +®liminant la perte de signal r+®seau caus+®e par l'oxydation ou la corrosion.
  • Les protections des clips du connecteur RJ45 +®vitent que les prises s'accrochent lors du passage du c+óble, ce qui facilite l'acheminement du c+óble Cat5e.
  • B+®n+®ficie de la garantie +á vie StarTech.com
Product codes
Make Fast Ethernet network connections using this high quality Cat5e Cable, with Power-over-Ethernet capability. The 45PAT15MGR Cat5e Patch Cable (15m) meets or exceeds all Cat 5e specifications to ensure reliable Ethernet network connections, and features a durable gray PVC jacket that enables you to color code your network cable runs as needed.
To ensure long-lasting performance, this high quality Cat5e patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance.
Constructed of only top quality materials, this Cat5e Patch Cord delivers reliable performance.
StarTech.com Cat5e cables are manufactured using high-quality copper conductors. While many cable manufacturers offer a "cheaper" cable, based on a copper-coated aluminum core, StarTech.com makes no compromises on quality to ensure you receive top value and performance for your network cable investment.
This Cat 5e cable is constructed with 24 gauge copper wire, to support a broad range of Ethernet applications such as Power over Ethernet (PoE). Because StarTech.com uses a high quality copper wire, these cables easily sustain the power required for Power over Ethernet applications, whereas the inferior quality offered by copper-coated aluminum cables may be subject to insufficient power delivery, heat buildup, equipment damage and potentially, fire.
This RJ45 patch cable offers high quality connectors comprised of 50-micron gold, to deliver optimum conductivity while eliminating signal loss due to oxidation or corrosion.
StarTech.com Snagless Cat 5e UTP Patch Cable - patch cable - 15 m - grey
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wires per Cable
8 wires
Molded, snagless
Length
15 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Grey
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 15 m Cat5...
£9.60
