StarTech.com 15cm (6in) Mobile Charge Sync USB to Slim Micro...
StarTech.com 15cm (6in) Mobile Charge Sync USB to Slim Micro USB Cable for Smartphones and Tablets
£4.10
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
  • Length: 15cm
  • Stock Status: In Stock
Product codes
Charge and Sync your Micro USB-equipped Smartphone or Tablet with reduced clutter. The USBAUB15CMBK Micro USB Cable is perfect for close-range connections, and provides a reliable solution for charging and syncing your Micro USB mobile devices. Plus, the cable offers a slim design that lets you plug into your device without having to take it out of its case for every charge and sync.
The short 15cm cable length makes this an ideal charge cable for in-car use or to reduce clutter when syncing to your laptop - perfect for people on the move, for providing simple, tidy connections.
Replace the cable that came with your device and keep one as a spare in your laptop bag, backpack or other carrying case.
Stop removing the case from your phone or tablet every time you charge or sync your device. The cable offers a slim Micro USB connector molding that plugs into your device even while it's inside a protective case.
Product Description StarTech.com Short Micro-USB cable - 15cm (6in) - USB cable - 15 cm
Type USB cable
Technology Double shielded
Length 15 cm
Connector 5 pin Micro-USB Type B - male
Connector (Second End) 4 pin USB Type A - male
Compliant Standards USB / USB 2.0
Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 15cm (6in...
£4.10
