StarTech.com 15cm (6in) Short Black Apple 8-pin Lightning Con...
StarTech.com 15cm (6in) Short Black Apple 8-pin Lightning Connector to USB Cable iPhone iPod iPad
£12.28
Colours:
Delivery:
Standard: 1-3 working days
Key features
  • Eliminates unnecessary clutter with a shorter cable design
  • Simple to store in a tablet or laptop carrying case, as a portable connectivity solution
  • Complements your black Apple mobile devices
  • Length: 15cm
  • Stock Status: In Stock
Product codes
Charge and Sync your Apple Lightning-equipped devices with reduced clutter. The USBLT15CMB 6in/15cm Black Lightning to USB Cable for iPhone, iPod and iPad enables close-range syncing and charging of your Lightning-enabled mobile digital devices. The cable is colored to suit black mobile devices and is short enough to minimize the clutter of excess cable, making it ideal for charging in your vehicle or for syncing to your laptop. Plus, the shorter cable design provides a portable solution that makes it perfect for carrying as a tablet or laptop accessory.
The reversible 8-pin Lightning connector can be plugged into your iOS-enabled device with either side facing up, meaning there is no wrong way of inserting the cable into the device.
This durable cable is Apple MFi certified.
If your computer USB port does not deliver sufficient power and you see a "Not Charging" message on your iPad or other Apple device, you can use this 15cm Lightning to USB Cable with the USB 2.0 Fast Charging Adapter (USB2CHADP) in order to fast charge your devices.
Product Description StarTech.com 6in Short Black Apple 8pin Lightning to USB Cable iPhone iPad - Lightning cable - Lightning / USB - 15 cm
Cable Lightning cable - Lightning / USB
Technology Double shielded
American Wire Gauge (AWG) 24/28/32
Length 15 cm
Colour Black
Connector Lightning - male
Connector (Second End) USB - male
Features Sync and charge
Designed For Apple iPad mini; iPad with Retina display (4th generation); iPhone 5, 5c, 5s; iPod nano (7G); iPod touch (5G)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 15cm (6in...
£12.28
