StarTech.com 15ft Coax High Resolution 90 degree Down Angled...
StarTech.com 15ft Coax High Resolution 90 degree Down Angled VGA Monitor Cable - HD15 M/M
£14.73
Select:
Delivery:
Standard: 1-3 working days
  • Type: VGA
  • Length: 4.6m
  • Stock Status: In Stock
Product codes
Connect your VGA monitor with the highest quality connection available, even in tight spaces. This 15ft High Resolution Video VGA Cable (90 degree) is designed to provide the highest video quality possible through a VGA connection and is specifically constructed to accommodate tight installation spaces.
The high quality, shielded coax VGA cable features a 90 degree down-angled plug, which requires only 32.4mm (1.27") of space to make the video connection.
More than suitable for high-res VGA applications (1280x1024 resolution and above), the 90 degree VGA cable eliminates picture "ghosting" and fuzzy images that are common with non-coaxial cables, and provides superior EMI interference protection using ferrite cores near the connector ends.
Product Description StarTech.com "15ft Coax High Resolution 90° Down Angled VGA Monitor Cable - HD15 M/M (MXT101MMHD15)" - VGA cable - 4.6 m
Type VGA cable
Features 90° connector, ferrite bead
Length 4.6 m
Connector HD-15 (VGA) - male
Connector (Second End) HD-15 (VGA) - male
Compliant Standards RoHS
Colour Black
Designed For P/N: CDP2VGA, CDP2VGAFC, HDMIPLATE, VGAPLATE
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 15ft Coax...
£14.73
