StarTech.com 15ft DVI Monitor Ext Cable
£17.54
Delivery:
Standard: 1-3 working days
  • Type: DVI
  • Length: 4.6m
  • Stock Status: In Stock
Product codes
Extend your high-speed DVI-D connection with StarTech.com's quality DVI-D extension cables. Ideal for laptop-to-projector digital presentations or for connecting your flat-panel LCD monitor to your digital video card, these male-to-female cables allow you extend your existing digital connection by 15 feet. These Plug and Play-compatible, single-link cables provide a faster, stronger signal than standard extension cables, giving you crystal-clear digital pictures.
These cables work with any DVI-D single-link cables or devices and allow high-speed data transmission up to 4.95 Gbits/sec.
Product Description StarTech.com DVI Extension Cable - 15 ft - Single Link - Male to Female Cable - 1920x1200 - DVI-D Cable - Computer Monitor Cable - DVI Cord (DVIDSMF15) - DVI extension cable - 4.6 m
Type DVI extension cable - single link
Length 4.6 m
Connector DVI-D - male
Connector (Second End) DVI-D - female
Compliant Standards Plug and Play
Colour Black
Designed For P/N: CDP2DVIMM2MB, DP2DVI2MM3, DP2DVI2MM6, DP2DVIMM10, DP2DVIMM6, DP2DVIMM6BS, DP2DVIMM6X10, DVIDSMM10, DVIMM6, HDDVIMM3, HDMIDVIMM10, HDMIDVIMM6
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 15ft DVI...
£17.54
