StarTech.com 15m / 50 ft Active USB 2.0 A to B Cable - M/M
£30.91
Select:
Delivery:
Standard: 1-3 working days
  • Length: 15m
  • Stock Status: In Stock
Product codes
Connect USB 2.0 devices up to 50ft away, with no signal loss. The USB2HAB50AC 50ft / 15m USB A to B cable incorporates bus-powered active circuitry, which enables it to perform beyond the 5-meter limit of a standard USB cable.
The longer connection provides enough cable length to connect your USB 2.0 peripherals up to 15m away from your PC, Laptop or Server, allowing you to position your devices as needed.
This active USB 2.0 cable is designed with top quality materials for high durability.
Product Description StarTech.com 15m / 50 ft Active USB 2.0 A to B Cable - M/M - USB cable - 15 m
Type USB cable
Technology Double shielded
Features Active cable (signal regeneration)
Length 15 m
Connector 4 pin USB Type B - male
Connector (Second End) 4 pin USB Type A - male
Compliant Standards USB / USB 2.0
Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 15m / 50...
£30.91
