StarTech.com 15m (50 ft) Active CL2 In-wall High Speed HDMI C...
StarTech.com 15m (50 ft) Active CL2 In-wall High Speed HDMI Cable - Ultra HD 4k x 2k HDMI Cable
£82.17
17 in stock
Delivery:
Standard: 1-3 working days
Product codes
The HDMM15MA 50 ft Active High Speed HDMI® Cable features a built-in active signal booster for a connection distance of up to 50 feet (15m) between your HDMI-enabled devices, with no signal loss.
This durable yet lightweight cable features thinner HDMI wire construction that allows for a more flexible installation with minimal clutter. Plus, the cable features built-in amplifier circuitry which actively boosts the HDMI signal with no external power required.
This 15 meter HDMI cable is backed by StarTech.com's 2-year Warranty.
Please Note: This cable features unidirectional architecture which requires that the cable is installed in the correct direction. Please refer to the "source" and "display" labels on the HDMI connectors in order to ensure that the device and the HDMI source are connected properly.
The StarTech.com Advantage
No HDMI signal loss, even at a distance of up to 50 feet (15 meters) Flexible construction for easier installations
Technical Specifications
  • Warranty 2 Years
  • Connector Plating Gold
  • Cable Jacket Type PVC - Polyvinyl Chloride
  • Cable Shield Type Aluminum-Mylar Foil with Braid
  • Fire Rating CMG Rated (General Purpose)
  • Connector A 1 - HDMI (19 pin) Male
  • Connector B 1 - HDMI (19 pin) Male
  • Cable Length 15 m [49.2 ft]
  • Color Black
  • Connector Style Straight
  • Product Length 15 m [49.2 ft]
  • Product Weight 1.1 kg [2.5 lb]
  • Wire Gauge 26 AWG
Product Description StarTech.com 15m Active CL2 In-wall High Speed HDMI Cable Ultra HD 4k x 2k - HDMI cable HDMI to HDMI - 15 m
Cable HDMI cable
Technology Double shielded
American Wire Gauge (AWG) 26
Length 15 m
Colour Black
Connector HDMI - male
Connector (Second End) HDMI - male
Features Active cable (signal regeneration)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 15m (50 f...
£82.17
