StarTech.com 15m 49ft 40G QSFP+ AOC Cable
£406.16
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • 100% compatibility with Cisco QSFP-H40G-AOC15M guaranteed
  • StarTech.com SFP cables are backed by a lifetime warranty
  • Meets or exceeds OEM specifications and MSA (Multi-Source Agreement) industry standards
Product codes
Connect your Cisco compliant 40GbE QSFP+ network devices with this cost-effective, active optical cable. This 40G QSFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
This active optical cable (AOC) is fully hot-pluggable and supports 40 Gigabit Ethernet applications connected through QSFP+ (Quad Small Form-Factor Pluggable) ports. The AOC cable is lighter and more flexible than QSFP+ direct-attach cables which makes it ideal for installation in tight spaces and over longer distances.
Designed for high-speed interconnects, this low-power, low-latency optical cable is ideal for applications such as point-to-point across-rack network switch or server connections.
StarTech.com Cisco QSFP-H40G-AOC15M Compatible QSFP+ Active Optical Cable - 15 m (49 ft) - 40 GbE - 40GBase direct attach cable - 15 m - black
40GBase direct attach cable - SFF-8436
Twinaxial
Active cable
Length
15 m
Connector
QSFP+ - latched
Connector (Second End)
QSFP+ - latched
2 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 15m 49ft...
£406.16
