StarTech.com 15m Active DisplayPort Cable - DP to DP M/M
£98.23
15 in stock
Delivery:
Standard: 1-3 working days
  • Length: 15m
  • Stock Status: In Stock
Product codes
Connect DisplayPort-equipped devices up to 15m away with no signal loss. The DISPL15MA 15m Active DisplayPort Cable features a built-in active signal booster for a connection distance of up to 50 feet (15m) between your DisplayPort-enabled devices - more than double the DisplayPort connection distance limitation of 16ft, with no signal loss.
This durable yet lightweight active DP cable features a thinner 32 AWG wire construction that allows for a more flexible installation with minimal clutter. Plus, the cable features built-in amplifier circuitry which actively boosts the DisplayPort signal with no external power needed.
The 15m cable offers a bandwidth of 10.8 Gbps with support for maximum resolutions up to WQXGA (2560×1600) and optional audio support. The cable is both HDCP and DPCP capable, which ensures that digitally protected content is displayed properly.
This cable features unidirectional architecture which requires that the cable is installed in the correct direction. Please refer to the "source" and "display" labels on the DisplayPort connectors, in order to ensure that the display device (monitor, projector etc.) and the DisplayPort source are connected properly.
Product Description StarTech.com 15m Active DisplayPort Cable - DP to DP M/M - DisplayPort cable - 15 m
Type DisplayPort cable
Technology Double shielded
Features Active cable (signal regeneration), latched, DPCP compliant
Length 15 m
Connector DisplayPort - male
Connector (Second End) DisplayPort - male
Compliant Standards RoHS
Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 15m Activ...
£98.23
