StarTech.com 15m CL2 Active HDMI Cable - 4K
£104.02
Select:
Delivery:
Standard: 1-3 working days
  • Length: 15m
  • Stock Status: In Stock
Product codes
Create feature-rich HDMI connections, up to 15 m away with no signal loss. This CL2 HDMI cable is rated for in-wall installations. It also has a built-in active signal booster that allows for a connection distance of up to 50 feet (15 m) between your HDMI devices, with no signal loss. The cable is also backward compatible with previous HDMI specifications and will work with all of your existing HDMI devices.
The cable's built-in amplifier circuitry actively boosts the HDMI signal with no external power required. It supports longer connections than regular HDMI. The active cable also features a thinner wire construction for more flexibility, making it ideal for in-wall installations.
This 4K HDMI cable supports resolutions of up to 4K@60Hz (3840x2160p) and bandwidths of up to 18Gbps. It also supports HDR (High Dynamic Range) for higher contrast ratio and vivid colors.
With higher resolutions, increased speeds, and sharper images, the cable provides the very best HDMI capabilities available today. It's the perfect cable for creating the ultimate home-theater experience, for providing lifelike digital signage, or for delivering exceptional presentations.
The cable also supports up to 32 uncompressed digital audio channels to provide crystal-clear sound.
Product Description StarTech.com CL2 HDMI Cable - 50 ft / 15m - Active - High Speed - 4K HDMI Cable - HDMI 2.0 Cable - In Wall HDMI Cable with Ethernet (HD2MM15MA) - HDMI cable - 15 m
Cable HDMI cable
Length 15 m
Connector HDMI - male
Connector (Second End) HDMI - male
Features 4K support
Designed For P/N: ST122HD202, ST124HD202
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 15m CL2 A...
£104.02
