StarTech.com 15m Coax High Resolution Monitor VGA Cable - HD1...
StarTech.com 15m Coax High Resolution Monitor VGA Cable - HD15 M/M
£43.71
47 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Backed by StarTech.com's Lifetime warranty
  • Delivers high resolution from your PC to your VGA display (1920x1200 or above)
  • Extends your VGA signal to work with your monitor, splitters, and projectors
  • Length: 15m
  • Stock Status: In Stock
Product codes
Connect your VGA monitor with the highest quality connection available. This 15-meter high resolution VGA monitor cable is designed to provide the highest video quality possible through VGA.
Ideally suited for high resolution VGA applications, this high quality male-to-male coaxial VGA cable eliminates the picture "ghosting" and fuzzy images that are inherent to non-coaxial cables, while providing superior EMI interference protection by using ferrite cores near the connector ends.
Product Description StarTech.com 15m Coax High Resolution Monitor VGA Cable HD15 M/M - VGA cable - 15 m
Type VGA cable
Technology Triple shielded twisted pair coaxial
Features Molded
Length 15 m
Connector HD-15 (VGA) - male
Connector (Second End) HD-15 (VGA) - male
Compliant Standards RoHS
Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 15m Coax...
£43.71
