StarTech.com 15m Grey Gigabit Snagless RJ45 UTP Cat6 Patch Cable
£16.47
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • High quality 24 AWG copper wire
  • ETL Verified
  • HIGH PERFORMANCE CAT6 ETHERNET CABLE: 100% copper for error-free Multi Gigabit 1/2.5/5Gbps connections; 10Gbps up to 50m; Fluke patch cord tested to comply w/ANSI/TIA-568-2.D Category 6 & ETL Verified
  • POE SUPPORT: 24 AWG stranded copper conductors & UL rated wiring supports up to 100W for PoE devices like VOIP phone & security systems; IEEE 802.3bt & DTE power compliance reduces cable heating
  • QUALITY CONSTRUCTION: ETL & UL certified wire; 50-micron gold-plated connectors prevent rust/corrosion to avoid costly network downtime; High quality PVC jacket resists bending or fraying damage
  • EASY INSTALLATION: Snagless patch cord for easy installation & flexible disconnection in wiring conduits; Compatible w/Cat5e & earlier standards; Molded boots available for constrained spaces
  • Length: 15m
  • Colour: Grey
  • Stock Status: In Stock
Product codes
Make Power-over-Ethernet-capable Gigabit network connections. The N6PATC15MGR Cat 6 Patch Cable (15m) meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections, and features a durable gray PVC jacket that enables you to color code your network cable runs as needed. To ensure long-lasting performance, this high quality Cat 6 patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance. Constructed of only top quality materials, this Cat 6 Patch Cord delivers reliable performance.
Product Description StarTech.com 15m CAT6 Ethernet Cable - Grey Snagless Gigabit CAT 6 Wire - 100W PoE RJ45 UTP 650MHz Category 6 Network Patch Cord UL/TIA (N6PATC15MGR) - patch cable - 15 m - grey
Type Patch cable - CAT 6
Technology Unshielded twisted pair (UTP)
Wiring Scheme T568B
Features Molded, snagless
Length 15 m
Connector RJ-45 - male
Connector (Second End) RJ-45 - male
Colour Grey
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 15m Grey...
£16.47
