StarTech.com 15m QSFP+ Breakout Cable
Key features
  • 100% compatibility with Cisco QSFP-4X10G-AOC10M guaranteed
  • StarTech.com SFP cables are backed by a lifetime warranty
  • Meets or exceeds MSA (Multi-Source Agreement) industry standards
Product codes
Connect four Cisco 10GbE SFP+ network devices with this cost-effective, active optical cable. This QSFP+ breakout cable connects a single QSFP+ port to four 10G SFP+ ports and delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
This active optical cable (AOC) is fully hot-pluggable and supports 40 Gigabit Ethernet applications connected through QSFP+ (Quad Small Form-Factor Pluggable) ports. The AOC cable is lighter and more flexible than QSFP+ direct-attach cables which makes it ideal for installation in tight spaces and over longer distances.
Designed for high-speed interconnects, this low-power, low-latency optical cable is ideal for applications such as point-to-point across-rack network switch or server connections, for up to four 10G SFP+ devices.
Product Description StarTech.com Cisco QSFP-4X10G-AOC10M Compatible QSFP+ Breakout Cable - 15 m - breakout cable - 15 m - black
Type Breakout cable - SFF-8431/SFF-8432/SFF-8436
Technology Fibre optic
Features Active cable
Length 15 m
Connector QSFP+ - latched
Connector (Second End) 4 x SFP+ - latched
Colour Black
OEM Manufacturer Equivalent Part Number Cisco QSFP-4X10G-AOC10M
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 15m QSFP+...
