StarTech.com 15m Red Gigabit Snagless RJ45 UTP Cat6 Patch Cable
£16.60
31 in stock
Delivery:
Standard: 1-3 working days
Key features
  • RJ45 connector clip protectors help keep the plugs from snagging while routing the cable, for easier Cat 6 cable runs
  • Backed by StarTech.com lifetime warranty
  • 50-micron gold connectors ensure optimum conductivity while eliminating signal loss due to oxidation or corrosion
Product codes
Make Power-over-Ethernet-capable Gigabit network connections. The N6PATC15MRD Cat 6 Patch Cable (15m) meets or exceeds all Category 6 cable specifications to ensure reliable Gigabit network connections, and features a durable red PVC jacket that enables you to color code your network cable runs as needed. To ensure long-lasting performance, this high quality Cat 6 patch cable features a snagless design that protects the RJ45 connector clips from damage and makes the cable less prone to snagging during installation. The cable also features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance. Constructed of only top quality materials, this Cat 6 Patch Cord delivers reliable performance.
Product Description StarTech.com 15m Red Cat6 / Cat 6 Snagless Patch Cable 15 m - patch cable - 15 m - red
Type Patch cable - CAT 6
Technology Unshielded twisted pair (UTP)
Features Molded, snagless
Length 15 m
Connector RJ-45 - male
Connector (Second End) RJ-45 - male
Colour Red
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 15m Red G...
£16.60
