StarTech.com 15m USB 2.0 Active Cable with 4 Port Hub
£71.18
14 in stock
Delivery:
Standard: 1-3 working days
  • Type: USB Hub
  • Ports: 4
  • Stock Status: In Stock
Product codes
Connect 4 USB 2.0 devices up to 15-meters away from your computer. The USB2EXT4P15M 15m Active USB 2.0 Extension Cable features an integrated 4-Port Hub that lets you connect up to 4 USB 2.0 devices while overcoming distance restrictions and power source limitations.
The active USB 2.0 extension cable ensures performance beyond the 5-meter length limits of standard USB cables. Perfect for applications where you need to extend the connection distance of your USB peripherals, enabling you to connect them up to 15-meters (50-feet) away from the host computer.
Plus, the cable allows you to maximize the number of devices connected to your computer by allowing you to connect up to 4 devices through a single connection. For added convenience, the cable comes with a 2A power adapter to provide power to your 4 connected USB devices.
The USB2EXT4P15M cable supports the full USB 2.0 bandwidth of 480 Mbps.
Product Description StarTech.com 15m USB 2.0 Active Cable with 4 Port Hub - hub - 4 ports
Device Type Hub - 4 ports
Subtype USB
Ports 4 x USB 2.0
Performance Maximum data rate: 480 Mpps
Features Over-current protection
Power AC 120/230 V
Weight 700 g
Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 15m USB 2...
£71.18
