Connect 4 USB 2.0 devices up to 15-meters away from your computer. The USB2EXT4P15M 15m Active USB 2.0 Extension Cable features an integrated 4-Port Hub that lets you connect up to 4 USB 2.0 devices while overcoming distance restrictions and power source limitations.
The active USB 2.0 extension cable ensures performance beyond the 5-meter length limits of standard USB cables. Perfect for applications where you need to extend the connection distance of your USB peripherals, enabling you to connect them up to 15-meters (50-feet) away from the host computer.
Plus, the cable allows you to maximize the number of devices connected to your computer by allowing you to connect up to 4 devices through a single connection. For added convenience, the cable comes with a 2A power adapter to provide power to your 4 connected USB devices.
The USB2EXT4P15M cable supports the full USB 2.0 bandwidth of 480 Mbps.
Product Description | StarTech.com 15m USB 2.0 Active Cable with 4 Port Hub - hub - 4 ports | Device Type | Hub - 4 ports | Subtype | USB | Ports | 4 x USB 2.0 | Performance | Maximum data rate: 480 Mpps | Features | Over-current protection | Power | AC 120/230 V | Weight | 700 g | Colour | Black | Manufacturer Warranty | 2-year warranty |
General | |
Enclosure Type | Desktop |
Subtype | USB |
Status Indicators | Active |
Expansion / Connectivity | |
Interfaces | 4 x USB 2.0 Type A |
Power | |
Voltage Required | AC 120/230 V |
Miscellaneous | |
Colour | Black |
Cables Included | 1 x SuperSpeed USB cable - 15 m |
Compliant Standards | Plug and Play, FCC, RoHS |
Dimensions & Weight | |
Weight | 700 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
