StarTech.com 16 Port Low Profile RS232 PCI Express Serial Car...
StarTech.com 16 Port Low Profile RS232 PCI Express Serial Card - Cable Included
Product codes
The PEX16S952LP PCI Express serial card (16950 UART) lets you turn a low profile PCIe slot into sixteen RS232 (DB9) serial connections. The serial adapter card is based on a native single chip design that allows you to harness the full capability of PCI Express (PCIe), delivering optimum reliability and speed while reducing the load applied to the CPU by as much as 48% over conventional serial cards. This low profile serial card is compatible with a broad range of operating systems, including Windows 2000, XP, 2003, Vista and Windows 7, and features a VHDCI 68 pin connector and serial breakout cable for installation into a single low profile expansion card slot. The card also includes a full-sized bracket, for installation in standard form factor computers.
StarTech.com 16 Port Low Profile RS232 PCI Express Serial Card - Cable Included - serial adapter
Serial adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express
Ports
RS-232 x 16
6.8 cm x 17.8 cm x 2 cm
1.3 kg
Cabling Type
Serial RS-232
Microsoft Windows 2000, Linux 2.4.x, Linux 2.6.x, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits)
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 16 Port L...
