StarTech.com 16 Port Rackmount FTDI USB to Serial COM Adapter...
StarTech.com 16 Port Rackmount FTDI USB to Serial COM Adapter Hub - RS232 Multiplexer
Key features
  • Adding 16 ports using a single USB port delivers maximum control of several RS232 serial devices, without having to purchase multiple I/O cards
  • Extended, hardened operating temperature range allows the device to remain operational in harsh conditions
  • Rack-mountable, all-metal chassis for durability in industrial environments
Product codes
Convert a single USB port into 16 RS232 serial ports in a hardened industrial-grade rack-mountable chassis. The ICUSB23216F 16-Port Rack Mountable FTDI USB Serial Hub (FTDI) adds 16 RS232 Serial ports with data transfer rates up to 921.6 Kbps, for control by a desktop or laptop computer system using a single USB port. This durable, hardened USB to RS232 hub offers an all metal chassis, which fits into standard 19-inch server storage racks for an organized industrial USB to COM port solution, and supports an extended -40?°C to 85?°C (-40?°F to 185?°F) operating temperature range that allows for reliable use in even the harshest environments. The hub features COM port retention, retaining assigned serial COM port values, allowing the same values to automatically be re-assigned to the port provided by the adapter in the event it is disconnected, then re-connected to the host computer. The USB-serial hub includes both an AC adapter and Terminal Block power options and features a reliable FTDI USB to serial chipset that offers simple installation into a broad range of operating systems including Windows, Linux and Mac OS.
StarTech.com 16 Port Rackmount FTDI USB to Serial COM Adapter Hub - RS232 Multiplexer - serial adapter
Serial adapter
Rack-mountable
Interface (Bus) Type
USB 2.0
Ports
RS-232 x 16
12 cm x 4.5 cm x 43 cm
RS-232
Data Transfer Rate
921.6 Kbps
AC 120/230 V
Apple MacOS 9.x, Apple MacOS X, Microsoft Windows Server 2003, Linux 2.4.x, Linux 2.6.x, Microsoft Windows Server 2008 R2, Microsoft Windows 2000/XP/Vista/7
2 years warranty
Customer reviews
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 16 Port R...
