Product Description | StarTech.com 16ft (5m) Premium Certified HDMI 2.0 Cable - High-Speed Ultra HD 4K 60Hz HDMI Cable with Ethernet - HDR10, ARC - UHD HDMI Video Cord - For UHD Monitors, TVs, Displays - M/M - HDMI cable with Ethernet - 5 m | Cable | Premium High Speed - HDMI cable with Ethernet | Technology | Shielded | American Wire Gauge (AWG) | 28 | Length | 5 m | Colour | Grey, black | Connector | HDMI - male | Connector (Second End) | HDMI - male | Features | Passive cable, 4K60Hz (3840 x 2160) support | Manufacturer Warranty | Limited lifetime warranty |
General | |
Cable Type | Premium High Speed - HDMI cable with Ethernet passive, 4K60Hz (3840 x 2160) support |
Jacket Material | Thermoplastic elastomer (TPE) |
Shielding Material | Aluminum mylar foil with braid |
Length | 5 m |
Plated Connector | Gold |
Features | Audio Return Channel (ARC), Dolby TrueHD support, Dolby DTS-HD Master Audio support, Dolby Atmos support, support HDR10, Dolby DTS 5.1 support, Dolby DTS:X support, 3D ready, colourimetry BT.2020 support, 18 Gbps data rate, Dolby DTS 7.1 support, strain relief, outer diameter 6.5mm |
Connectivity | |
Connector | 19 pin HDMI Type A - male |
Connector (Second End) | 19 pin HDMI Type A - male |
Miscellaneous | |
Compliant Standards | RoHS, WEEE, EMI |
Dimensions & Weight (Shipping) | |
Shipping Width | 39.5 cm |
Shipping Depth | 13.8 cm |
Shipping Height | 7 cm |
Shipping Weight | 230 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - lifetime |
To help you find items available at this time, we’re only showing items we have in stock to avoid backorders. Pop your email address below and we’ll let you know when this item is back in stock:
