StarTech.com 16in (40cm) 9 Pin Serial Male to 10 Pin Motherbo...
StarTech.com 16in (40cm) 9 Pin Serial Male to 10 Pin Motherboard Header Slot Plate
£3.93
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
  • Length: 41cm
  • Stock Status: In Stock
Product codes
This 9-pin Serial to 10-pin Header Slot Plate adapter features one DB9 male connector and one IDC10 connector. The adapter is constructed of high quality components and expertly designed to ensure durability and reliability.
Please refer to the Technical Specifications to ensure your motherboard is compatible with this product.
Product Description StarTech.com 16in (40cm) 9 Pin Serial Male to 10 Pin Motherboard Header Slot Plate - motherboard Serial Port Adapter (PLATE9M16) - serial panel - 41 cm
Type Serial panel
Length 41 cm
Connector 9 pin D-Sub (DB-9) - male
Connector (Second End) 10 PIN IDC - female
Colour Grey
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 16in (40c...
£3.93
