StarTech.com 16in 9 Pin Serial Male to 10 Pin Motherboard Hea...
StarTech.com 16in 9 Pin Serial Male to 10 Pin Motherboard Header Panel Mount Cable
£6.26
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Length: 40.7cm
  • Stock Status: In Stock
Product codes
Turn a Motherboard IDC Serial Header into a Panel-Mountable 9-Pin RS232 Serial Connector.
The PNL9M16 16-inch IDC Serial to Panel Mount Serial Cable, features a 10-pin (IDC) motherboard header connection on one end and a panel mount DB9 male connector port on the other - a simple answer for adding a DB9 (RS232) serial port to any computer system which has an RS232 serial panel mount receptacle.
This cost-effective solution bridges the compatibility gap between modern computers and legacy serial peripherals.
Product Description StarTech.com "16"" 9 Pin Serial Male to 10 Pin Header Panel Mount Cable " - serial cable - 40.7 cm
Type Serial cable
Length 40.7 cm
Connector 9 pin D-Sub (DB-9) - male
Connector (Second End) 10 PIN IDC - female
Colour Grey
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 16in 9 Pi...
£6.26
