StarTech.com 16in DB25 Parallel Female to IDC 25 Pin Header S...
StarTech.com 16in DB25 Parallel Female to IDC 25 Pin Header Slot Plate
£4.52
Delivery:
Standard: 1-3 working days
  • Length: 40.64cm
  • Stock Status: In Stock
Product codes
Add an extra parallel port to the back of your PC from your motherboard. This 25-pin Parallel to 25-pin Header Slot Plate features one DB25 Female connector and one IDC 25 connector.
Constructed of only top quality components, the Parallel Slot Plate adapter offers a cost-effective solution for adding a Parallel device connection using a compatible motherboard.
Product Description StarTech.com 16in DB25 Parallel Female to IDC 25 Pin Header Slot Plate (PLATE25F16) - parallel panel - 40.64 cm
Type Parallel panel
Length 40.64 cm
Connector 25 pin D-Sub (DB-25) - female
Connector (Second End) 26 PIN IDC - female
Colour Grey
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 16in DB25...
£4.52
