StarTech.com 180° Cat 6 Keystone Jack - RJ45 Ethernet Ca...
StarTech.com 180° Cat 6 Keystone Jack - RJ45 Ethernet Cat6 Wall Jack White - 110 Type
£4.75
25 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Backed by StarTech.com 2-year warranty
  • Solid, one-piece plastic construction with a flexible 8-pin insert for added durability
  • Terminates Cat6 cables at a 180° angle, reducing the keystone profile within the wall jack, wall plate or patch panel
  • Type: Network Socket
  • Stock Status: In Stock
Product codes
Terminate Cat6 cables at a 180° angle, for a more compact keystone jack installation. The C6KEY110SWH Cat6 Keystone Jack is designed to snap into wall plates, patch panels, and surface connection boxes for quick, seamless deployment.
Meeting and exceeding the international standard ISO / IEC 11801 and the ANSI/TIA-568-C.2 requirements, this RJ45 keystone jack provides the perfect solution for your Ethernet networks.
Product Description StarTech.com 180 Degree Cat 6 Keystone Jack - RJ45 Ethernet Cat6 Wall Jack White - 110 Type - Keystone Jack 180 Degree 110 UTP (C6KEY110SWH) - keystone jack
Product Type Keystone jack - CAT 6 - RJ-45
Weight 15.4 g
Colour White
Port Qty 1 port
Designed For P/N: WIRC6CMPBLU
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 180° Cat...
£4.75
