StarTech.com 18in Internal 5 pin USB IDC Motherboard Header C...
StarTech.com 18in Internal 5 pin USB IDC Motherboard Header Cable – F/F
£3.45
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Length: 45.7cm
  • Stock Status: In Stock
Product codes
This 18in internal USB IDC cable features two 5-pin USB motherboard header connectors, allowing you to connect a front panel USB hub or card reader directly to the motherboard header ports.
This cable provides a solution for connecting multi-function front panels, or any device that relies on internal USB ports, directly to the motherboard or expansion card offering USB an IDC (Header) connection without having to install additional cards, or run cables externally to the rear ports.
The 18in Internal IDC USB 5-pin Motherboard Header Cable is constructed of high quality materials and expertly constructed for durable performance.
Product Description StarTech.com 18in Internal 5 pin USB IDC Motherboard Header Cable - F/F - USB cable - 45.7 cm
Type USB cable
Length 45.7 cm
Connector 5 pin IDC - female
Connector (Second End) 5 pin IDC - female
Compliant Standards USB / USB 2.0
Colour Black
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 18in Inte...
£3.45
