StarTech.com 18in Latching Round SATA Cable
Key features
  • Backed by StarTech.com's Lifetime Warranty
  • Latching connectors secure the cable against accidental disconnection
  • Rounded cable design provides less airflow resistance than standard designs, which helps improve air flow within a computer/server case for optimum system performance
Product codes
Connect latching SATA drives while helping to ensure optimal airflow throughout a desktop or server case. The LSATARND18 18-inch latching round SATA cable is a high quality SATA 6Gbps cable that features a rounded design to help improve airflow inside a computer or server case by providing less resistance as air passes around the cable, in turn helping to ensure optimal cooling for optimized system performance. This durable cable also features latching connectors, which lock when connected to a supporting (latchable) SATA port to, ensuring a snug, secured data connection every time to prevent accidental disconnects.
Product Description StarTech.com 18in Latching Round SATA Cable - 18 SATA Cable - 18 round SATA Cable - 18 latching SATA Cable (LSATARND18) - SATA cable - 45.7 cm
Type SATA cable
Interface Speed Serial ATA 150/300/600
Features Latched, round
Length 45.7 cm
Connector 7 pin Serial ATA - receptacle
Connector (Second End) 7 pin Serial ATA - receptacle
Colour Black
Designed For P/N: 35S24M2NGFF, BRACKET125PT, BRACKET125PTP, BRACKET225PT, BRACKET425F, HSB13SATSASB, HSB1SATSASBA, HSB1SATSASVA, HSB225S3R, HSB2535SATBK, HSB3SATSASBA, HSB43SATSASB, HSB4SATSASBA, S251BU31REM, SATSASBP425, USB2SATAIDE, USB3SSATAIDE
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 18in Latc...
