StarTech.com 18in SAS 29 Pin to SATA Cable with LP4 Power
£9.27
13 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Allows you to connect a SAS hard drive to a SATA controller that supports SAS drives
  • One cable provides both power and data connections
  • Backed by StarTech.com lifetime warranty
  • Length: 46cm
  • Stock Status: In Stock
Product codes
Ideal for use with SAS external storage devices, Host Bus Adapters and RAID controllers, this high quality 18in SAS (29-Pin) to SATA Cable delivers both power (LP4) and data connectivity.
Please note that the SATA controller must support SAS drives.
Product Description StarTech.com 18in SAS 29 Pin to SATA Cable with LP4 Power - 18in SAS 29 pin to SATA Cable - 18in SFF 8482 to SATA (SAS729PW18) - SATA / SAS cable - 46 cm
Type SATA / SAS cable
Length 46 cm
Connectors 29 pin internal SAS (SFF-8482) - receptacle , 4 PIN internal power - male
Connectors (Second End) 7 pin Serial ATA - receptacle
Colour Red
Designed For P/N: DRW150SASBK
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 18in SAS...
£9.27
