StarTech.com 18in SATA Serial ATA Data and Power Combo Cable
£5.95
38 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Cost-effective solution for powering a SATA drive from an LP4 connection on the computer power supply, which eliminates the cost of a power supply upgrade for compatibility with SATA hard drives
  • Features a thin cable design, which helps reduce clutter and increase airflow within the computer/server case, for optimum system performance
  • Backed by StarTech.com lifetime warranty, ensuring a dependable connection
  • Length: 45.7cm
  • Type: ATA
  • Stock Status: In Stock
Product codes
Power your Internal SATA hard drive from an LP4 / Molex connector on your Power Supply. The SATA18POW SATA Data and Power Cable features a combination 22-pin SATA receptacle data and power connector as well as an Molex (LP4) power connector and SATA receptacle data connector, allowing you to create a conventional Serial ATA data connection to a computer while powering the drive through an LP4 connection to the computer power supply.
This high quality SATA power/LP4 adapter cable measures 18in, providing the flexibility required to position the SATA hard drive as needed within the computer case, while eliminating the expense of upgrading the computer power supply for the sake of SATA compatibility.
Product Description StarTech.com 18in SATA Serial ATA Data and Power Combo Cable - SATA cable - 45.7 cm
Type SATA cable
Interface Speed Serial ATA 150/300/600
Length 45.7 cm
Connectors 22 pin Serial ATA - receptacle
Connectors (Second End) 7 pin Serial ATA - receptacle , 4 PIN internal power - male
Colour Red
Designed For P/N: PEXSAT2IDE2, PCISAT2IDE1, SATABAY5BK, SATABAY3BK, SATABAY4BK, PCISATA4R1
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 18in SATA...
£5.95
