StarTech.com 18in SATA to Left Angle SATA Serial ATA Cable - F/F
£4.54
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Length: 46cm
  • Stock Status: In Stock
Product codes
Make a left-angled connection to your SATA drive, for installation in tight spaces. The SATA18LA1 Left Angle (90-degree) SATA Cable features a standard (straight) SATA receptacle as well as a left-angled SATA receptacle, providing a simple 18-inch connection to a Serial ATA drive, with full SATA 3.0 bandwidth support of up to 6Gbps when used with SATA 3.0 compliant drives.
The left-angled SATA connection enables you to plug in your Serial ATA hard drive in hard to reach areas or tight spaces, while the low profile and flexible design of the cable improves airflow and reduces clutter in your computer case, helping to keep the case clean and cool.
As an alternative, StarTech.com also offers an 18in Right Angle SATA cable (SATA18RA1), which provides the same simple installation as this left angled SATA cable, but allows the cable to connect to the SATA drive from the opposite direction.
Product Description StarTech.com 18in SATA to Left Angle SATA Serial ATA Cable - F/F - SATA cable - 46 cm
Type SATA cable
Interface Speed Serial ATA 150/300/600
Technology Shielded
Features Left-angled connector
Length 46 cm
Connector 7 pin Serial ATA - receptacle
Connector (Second End) 7 pin Serial ATA - receptacle
Colour Red
Designed For P/N: PEXESAT322I
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 18in SATA...
£4.54
