StarTech.com 18in SATA to Left Side Angle SATA Serial ATA Cable
£3.75
23 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Helps ensure optimum system performance by reducing clutter and increasing airflow within the computer/server case, using a thin cable design
  • Offers a reliable connection, guaranteed by a StarTech.com lifetime warranty
  • Provides maximum flexibility for positioning SATA drives within a computer case, using a left side-angled SATA connector that easily fits into narrow spaces
  • Length: 45.72cm
  • Stock Status: In Stock
Product codes
Make a left side-angled connection to your SATA drive, for installation in narrow spaces. The SATA18LSA1 Left Side-Angled SATA Cable (18-inch) features one straight and one left side-angled (7-pin) data receptacle, which positions the cable so that it runs parallel to the drive ports - ideal for connectivity in narrow spaces, enabling installation of the drive as needed within the system case.
The cable also features a flexible low profile design that helps improve airflow and reduce clutter in your computer case, which helps keep the case clean and cool.
Constructed of only top quality materials and designed for optimum performance and reliability this 18" SATA cable supports full SATA 3.0 bandwidth (up to 6Gbps) when used with SATA 3.0 compliant drives.
Product Description StarTech.com SATA to Left Side Angle SATA Serial ATA Cable - SATA cable - 45.72 cm
Type SATA cable
Interface Speed Serial ATA 150/300/600
Features Left-angled connector
Length 45.72 cm
Connector 7 pin Serial ATA - receptacle
Connector (Second End) 7 pin Serial ATA - receptacle
Colour Red
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 18in SATA...
£3.75
