StarTech.com 1ft Coiled Lightning/USB Cable
£11.67
Colours:
Delivery:
Standard: 1-3 working days
Key features
  • Ideal for close-range connections – great for charging in your car
  • Lightweight, portable cable, suitable for carrying as an iPad or iPhone accessory
  • Guaranteed reliability
  • Length: 30cm
  • Stock Status: In Stock
Product codes
Charge your iPad or iPhone inside its car mount. This coiled Lightning cable delivers the compact convenience you need to keep your mobile devices charged while you're driving, without cluttering up your car.
Simply plug the cable into your USB car charger and stretch it out to connect your mobile device when you need to charge it. You can extend the cable up to 1 ft (0.3m), to comfortably reach your car-mounted tablet or phone.
When you're not charging your mobile device, you can neatly store this compact cable in your car's storage console or glove box. Plus, it's portable enough to keep it in your laptop bag or carrying case, so you can have it handy when you arrive at your destination and use it as a conventional charge-and-sync cable.
The USBCLT30CMW coiled Lightning cable is Apple MFi certified.
Product Description StarTech.com Lightning to USB Cable - Coiled Lightning Cable - 0.3m (1ft) - White - Apple MFi Certified (USBCLT30CMW) - Lightning cable - Lightning / USB - 30 cm
Cable Lightning cable - Lightning / USB
Technology Double shielded
American Wire Gauge (AWG) 28/30
Length 30 cm
Colour White
Connector USB - male
Connector (Second End) Lightning - male
Features Coiled
Designed For Apple iPad Air; iPad Air 2; iPad mini; iPad mini 2; 3; iPad with Retina display (4th generation); iPhone 5, 5c, 5s, 6, 6 Plus; iPod nano (7G); iPod touch (5G)
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1ft Coile...
£11.67
