StarTech.com 1ft Low Profile SATA to eSATA Plate Adapter
£5.40
Hurry, only 3 left in stock!
Delivery:
Standard: 1-3 working days
  • Length: 30cm
  • Type: SATA
  • Stock Status: In Stock
Product codes
This eSATA plate (low profile) adds external data support to any existing Serial ATA (SATA) controller, allowing you to connect external SATA (eSATA) storage to a computer. With support for data transfer rates of up to 300MBps, this external SATA plate allows you to take advantage of the increased data integrity provided by external hard drives or RAID devices that support eSATA connections. Connecting eSATA storage couldn't be simpler. Just install the plate into an open I/O low profile slot on your computer and connect the cables to the Serial ATA connectors on your motherboard or controller card. The slim SATA data cable connecting the motherboard or controller card SATA connection to ESATAPLT1LP is designed to take up minimal space inside the computer case, providing less clutter for increased airflow inside your case.
Product Description StarTech.com 1ft Low Profile SATA to eSATA Plate Adapter - SATA internal to external panel - 30 cm
Type SATA internal to external panel
Interface Speed Serial ATA 150/300/600
Features Low profile
Length 30 cm
Connector 7 pin Serial ATA - female
Connector (Second End) 7 pin external Serial ATA - male
Colour Red
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1ft Low P...
£5.40
