This angled USB to Lightning cable withstands the demands of charging and syncing your mobile devices. Tested for strenuous wear and tear, the Lightning cable's angled connector gives you easy access to your mobile device even while charging.
With Kevlar aramid fiber reinforcement, the durable Lightning cable is sheltered from the stress of frequent bends and twists, which allows the cable to flex without over-stretching.
Cable Key Features. Aramid fiber adds strength and durability to the cable. Insulated conductors reduce friction, provide more flexibility. EMI (electromagnetic interference) protection with aluminum-mylar foil and braided shielding. TPE (thermoplastic elastomer) cable jacket is softer and more flexible than a standard PVC cable.
Constructed to prevent the connector from separating from the cable jacket, the extra-long strain relief molding is tested to withstand over 10,000+ bend cycles at a 180° angle.
Connector Key Features. Lightning connector provides 12W for charging your iOS devices. Metal shield protects circuit board from EMI and reinforces the connection point. Strain relief tested to tolerate over 10,000+ bend cycles at a 180-degree angle.
Product Description | StarTech.com 3ft (1m) Durable USB A to Lightning Cable, Black 90° Right Angled Heavy Duty Rugged Aramid Fiber USB Type A to Lightning Charging/Sync Cord, Apple MFi Certified, iPhone 12 Pro - iPhone 7/8/11/11 Pro - Lightning cable - Lightning / USB - 1 m | Cable | Lightning cable - Lightning / USB | Technology | Double shielded | American Wire Gauge (AWG) | 22/32 | Length | 1 m | Colour | Black | Connector | Lightning - male - angled | Connector (Second End) | USB - male | Compliant Standards | USB / USB 2.0 | Features | Strain relief | Manufacturer Warranty | 2-year warranty | Designed For | Apple 10.5-inch iPad Air; 10.5-inch iPad Pro; 12.9-inch iPad Pro; 9.7-inch iPad; 9.7-inch iPad Pro; iPad Air; iPad Air 2; iPad mini 2; 3; 4; 5; iPad with Retina display; iPhone 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, 7, 7 Plus, 8, 8 Plus, SE, X, XR, XS, XS Max; iPod nano (7G); iPod touch (5G, 6G) |
General | |
Cable Type | Lightning cable |
Interface Supported | Lightning / USB |
Jacket Material | Thermoplastic elastomer (TPE) |
Shielding Material | Aluminum mylar foil with braid |
Length | 1 m |
Plated Connector | Nickel |
Colour | Black |
Connectivity | |
Connector | Apple Lightning - male - angled |
Connector (Second End) | 4 pin USB Type A - male |
Miscellaneous | |
Compliant Standards | RoHS, REACH, MFI, EMI |
Dimensions & Weight | |
Width | 2.61 cm |
Height | 0.7 cm |
Weight | 15 g |
Dimensions & Weight (Shipping) | |
Shipping Width | 7.5 cm |
Shipping Depth | 14.5 cm |
Shipping Height | 1.7 cm |
Shipping Weight | 100 g |
Manufacturer Warranty | |
Service & Support | Limited warranty - 2 years |
Compatibility Information | |
Designed For | Apple 10.5-inch iPad Air (3rd generation) , Apple 10.5-inch iPad Pro , Apple 12.9-inch iPad Pro (1st generation, 2nd generation) , Apple 9.7-inch iPad (5th generation, 6th generation) , Apple 9.7-inch iPad Pro , Apple iPad Air , Apple iPad Air 2 , Apple iPad mini 2 (2nd generation) , Apple iPad mini 3 (3rd generation) , Apple iPad mini 4 (4th generation) , Apple iPad mini 5 (5th generation) , Apple iPad with Retina display (4th generation) , Apple iPhone 5, 5c, 5s, 6, 6 Plus, 6s, 6s Plus, 7, 7 Plus, 8, 8 Plus, SE, X, XR, XS, XS Max , Apple iPod nano (7G) , Apple iPod touch (5G, 6G) |
