StarTech.com 1m (3 ft) Apple 30-pin Dock Connector to Right A...
StarTech.com 1m (3 ft) Apple 30-pin Dock Connector to Right Angle USB Cable - Stepped Connector
£6.22
31 in stock
Delivery:
Standard: 1-3 working days
Product codes
Charge and sync your Apple devices in their protective cases, even in hard to reach areas and tight spaces. The USB2ADC1MUR Apple (30-pin) Dock Connector to Right Angle USB Cable for iPhone, iPod and iPad (1m) offers a simple and reliable solution for connecting iOS-enabled mobile digital devices to your computer, for syncing or charging.
The right-angled USB connector allows for connection in tight spaces while the stepped Apple Dock Connector, designed by StarTech.com, plugs into your iPhone, iPod or iPad even when inside a protective case, avoiding the inconvenience of having to constantly remove the cover for every charge.
This durable cable is Apple MFi certified .
As an alternative, StarTech.com also offers a 1m Apple 30-pin Dock Connector to Left Angle USB Cable (USB2ADC1MUL), which provides the same convenience as this right-angled cable, but allows you to connect to your PC or Mac computer or your USB wall/vehicle charger from the opposite direction.
If your computer USB port does not deliver sufficient power and you see a "Not Charging" message on your iPad or other Apple device, you can use this 1m 30-pin Dock to USB Cable with the USB 2.0 Fast Charging Adapter (USB2CHADP) in order to fast charge your devices.
StarTech.com 1m Apple 30-pin Dock to Right Angle USB Cable iPhone iPod iPad - charging / data cable - 1 m
Cable
Charging / data cable
Shielded
American Wire Gauge (AWG)
22/30
Length
1 m
White
Connector
Apple Dock - male
Connector (Second End)
USB - male
Right-angled connector
Apple iPad (3rd generation); iPad 1; 2; iPhone 3G, 3GS, 4, 4S; iPod (4G, 5G); iPod classic; iPod mini; iPod nano (1G, 2G, 3G, 4G, 5G, 6G); iPod touch (1G, 2G, 3G, 4G)
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1m (3 ft)...
£6.22
