StarTech.com 1m (3 ft) Apple 30-pin Dock Connector to USB Cab...
StarTech.com 1m (3 ft) Apple 30-pin Dock Connector to USB Cable with Stepped Connector
£10.88
20 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Fully compatible with all iPod, iPhone and iPad devices
  • Charge your Apple devices anywhere you go from a computer, USB wall charger, or vehicle USB charger
  • Backed by StarTech.com Lifetime Warranty
  • Length: 1m
  • Stock Status: In Stock
Product codes
Charge or sync your Apple devices, even when inside a protective case. The USB2ADC1M Apple (30-pin) Dock Connector to USB cable for iPhone, iPod and iPad (1m) offers a simple and reliable solution for connecting iOS-enabled mobile digital devices to your computer, for syncing or charging.
Plus, the USB to iPhone cable features a uniquely constructed stepped Apple Dock Connector, designed by StarTech.com. Unlike a regular connector, the exclusive stepped connector plugs into your iPhone, iPod or iPad, even when inside a protective case, avoiding the inconvenience of having to constantly remove the cover for every charge/sync.
This durable cable is Apple MFi certified.
If your computer USB port does not deliver sufficient power and you see a "Not Charging" message on your iPad or other Apple device, you can use this 1m 30-pin Dock to USB Cable with the USB 2.0 Fast Charging Adapter (USB2CHADP) in order to fast charge your devices.
Product Description StarTech.com Apple 30-pin Dock Connector to USB Cable iPhone iPod iPad - charging / data adapter - 1 m
Cable Charging / data adapter
American Wire Gauge (AWG) 28
Length 1 m
Colour White
Connector Apple Dock - male
Connector (Second End) USB - male
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1m (3 ft)...
£10.88
