StarTech.com 1m (3 ft) Down Angle Apple 30-pin Dock Connector...
StarTech.com 1m (3 ft) Down Angle Apple 30-pin Dock Connector to USB Cable - Stepped Connector
£8.77
Delivery:
Key features
  • Durable, reliable performance is guaranteed by our lifetime warranty
  • Keeps the 30-pin dock connector to USB cable out of the way for a neater installation with mounted iPhone, iPod or iPad mobile devices
  • Protective casing doesn't need to be removed from the mobile device, to charge or sync
  • Length: 1m
Product codes
Charge or Sync your wall/stand-mounted iPhone, iPod or iPad with the cable out of the way. The USB2ADC1MD Dock Connector to USB cable for iPhone, iPod and iPad (1m) features a down-angled Apple (30-pin) Dock Connector, which is ideal for wall-mounted or stand-mounted applications because it positions the cable behind your iOS-enabled mobile digital device for a neater installation that keeps the cable out of the way.
Plus, this uniquely constructed Dock Connector to USB cable features a stepped Apple Dock Connector, designed by StarTech.com, which unlike a regular connector plugs into your iPhone, iPod or iPad, even when inside a protective case while avoiding the inconvenience of having to constantly remove the cover for every charge/sync.
This durable cable is Apple MFi certified.
If your computer USB port does not deliver sufficient power and you see a "Not Charging" message on your iPad or other Apple device, you can use this 1m 30-pin Dock to USB Cable with the USB 2.0 Fast Charging Adapter (USB2CHADP) in order to fast charge your devices.
Product Description StarTech.com 1m Down Angle Apple 30-pin Dock to USB Cable iPhone iPod iPad - charging / data cable - 1 m
Cable Charging / data cable
Technology Shielded
American Wire Gauge (AWG) 26
Length 1 m
Colour White
Connector USB - male
Connector (Second End) Apple Dock - male
Features Angled connector
Designed For Apple iPad (3rd generation); iPad 1; 2; iPhone 3G, 3GS, 4, 4S; iPod (4G, 5G); iPod classic; iPod mini; iPod nano (1G, 2G, 3G, 4G, 5G, 6G); iPod touch (1G, 2G, 3G, 4G)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1m (3 ft)...
£8.77
