StarTech.com 1m (3 ft) Right Angle Apple 30-pin Dock Connecto...
StarTech.com 1m (3 ft) Right Angle Apple 30-pin Dock Connector to USB Cable - Stepped Connector
£8.77
Delivery:
Key features
  • Backed by StarTech.com Lifetime Warranty
  • Keep your iOS-enabled mobile digital device in its protective case while charging, with our unique stepped Apple dock connector
  • Provides unrestricted access to your iPhone, iPod or iPad, in landscape or portrait mode, even while charging
  • Length: 1m
Product codes
Charge or Sync your iPhone, iPod, or iPad with the cable out of the way. The USB2ADC1MR USB cable for iPhone, iPod and iPad (1m) features a right-angled Apple (30-pin) Dock Connector which positions the cable in such a way that it allows you to easily access your iOS-enabled mobile digital device in both portrait and landscape mode, even while charging.
Plus, the USB to iPhone cable features a uniquely constructed stepped Apple Dock Connector, designed by StarTech.com. Unlike a regular connector, the exclusive stepped connector plugs into your iPhone, iPod or iPad, even when inside a protective case, avoiding the inconvenience of having to constantly remove the cover for every charge/sync.
This durable cable is Apple MFi certified.
As an alternative, StarTech.com also offers a 1m Left Angle Apple 30-pin Dock Connector to USB Cable (USB2ADC1ML), which provides the same convenience as this right-angled cable, but allows you to connect to your iPhone, iPod or iPad from the opposite direction.
If your computer USB port does not deliver sufficient power and you see a "Not Charging" message on your iPad or other Apple device, you can use this 1m 30-pin Dock to USB Cable with the USB 2.0 Fast Charging Adapter (USB2CHADP) in order to fast charge your devices.
Product Description StarTech.com Right Angle Apple 30-pin Dock to USB Cable iPhone iPod iPad - charging / data cable - 1 m
Cable Charging / data cable
Technology Shielded
American Wire Gauge (AWG) 26
Length 1 m
Colour White
Connector USB - male
Connector (Second End) Apple Dock - male
Features Angled connector
Designed For Apple iPad (3rd generation); iPad 1; 2; iPhone 3G, 3GS, 4, 4S; iPod (4G, 5G); iPod classic; iPod mini; iPod nano (1G, 2G, 3G, 4G, 5G, 6G); iPod touch (1G, 2G, 3G, 4G)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1m (3 ft)...
£8.77
