StarTech.com 1m (3ft) Angled Black Apple 8-pin Lightning Conn...
StarTech.com 1m (3ft) Angled Black Apple 8-pin Lightning Connector to USB Cable for iPhone iPod iPad
£15.64
Colours:
Delivery:
Standard: 1-3 working days
Key features
  • Provides unrestricted access to your iPhone, iPod or iPad, in landscape or portrait mode, even while charging
  • Complements your black Apple mobile devices
  • No incorrect way of plugging the connector into your mobile device
  • Length: 1m
  • Stock Status: In Stock
Product codes
Charge or Sync your iPhone, iPod, or iPad with the cable out of the way. The USBLT1MBR 1m Angled Lightning to USB Cable for iPhone, iPod, and iPad is colored to suit black mobile devices and provides a reliable solution for charging and syncing your newer generation Apple mobile devices with your PC or Mac computer, through an available USB port.
The angled Lightning connector positions the cable in such a way that it allows for easy access to your iOS-enabled mobile digital device in both portrait and landscape mode, even while charging.
Plus, the reversible 8-pin Lightning connector can be plugged into your iOS-enabled device with either side facing up, meaning there is no wrong way of inserting the cable into the device.
This durable cable is Apple MFi certified.
If your computer USB port does not deliver sufficient power and you see a "Not Charging" message on your iPad or other Apple device, you can use this 1m Lightning to USB Cable with the USB 2.0 Fast Charging Adapter (USB2CHADP) in order to fast charge your devices.
Product Description StarTech.com 1m 3ft Angled Black Apple 8-pin Lightning to USB Cable for iPhone iPod iPad - Angled Lightning Cable - Charge & Sync - 1 m (USBLT1MBR) - Lightning cable - Lightning / USB - 1 m
Cable Lightning cable - Lightning / USB
Technology Double shielded
American Wire Gauge (AWG) 22/28
Length 1 m
Colour Black
Connector Lightning - male
Connector (Second End) USB - male
Features Angled connector
Designed For Apple iPad Air; iPad mini; iPad mini 2; iPad with Retina display (4th generation); iPhone 5, 5c, 5s; iPod nano (7G); iPod touch (5G)
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1m (3ft)...
£15.64
