StarTech.com 1m (3ft) Blue Apple 8-pin Lightning Connector to...
StarTech.com 1m (3ft) Blue Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad
£14.05
Colours:
Delivery:
Standard: 1-3 working days
Key features
  • Colorful design complements your blue iPhone 5c
  • No incorrect way of plugging the connector into your mobile device
  • Guaranteed reliability, backed by StarTech.com 2-Year warranty
Product codes
Charge and Sync your Apple Lightning-equipped devices. The USBLT1MBL 1m Blue Lightning to USB Cable for iPhone, iPod, and iPad provides a stylish and reliable solution for charging and syncing your Apple 8-pin Lightning mobile devices.
The cable is colored to suit your blue iPhone 5c but it can be used with any of your Lightning iOS-enabled mobile devices - so don't be afraid to be colorful and select from any of the colored Lightning cables such as Pink, Green, Yellow or Blue. You can create the perfect color match with your iPhone or be creative with your own unique look!
Plus, the reversible 8-pin Lightning connector can be plugged into your iOS-enabled device with either side facing up, meaning there is no wrong way of inserting the cable into the device.
This durable cable is Apple MFi certified.
If your computer USB port does not deliver sufficient power and you see a "Not Charging" message on your iPad or other Apple device, you can use this 1m Lightning to USB Cable with the USB 2.0 Fast Charging Adapter (USB2CHADP) in order to fast charge your devices.
Product Description StarTech.com 1m Blue Apple 8-pin Lightning to USB Cable for iPhone iPad - Lightning cable - Lightning / USB - Lightning to USB - 1 m
Cable Lightning cable - Lightning / USB
Technology Double shielded
American Wire Gauge (AWG) 24/28/32
Length 1 m
Colour Blue
Connector Lightning - male
Connector (Second End) USB - male
Features Sync and charge
Designed For Apple iPad Air; iPad mini; iPad mini 2; iPad with Retina display (4th generation); iPhone 5, 5c, 5s; iPod nano (7G); iPod touch (5G)
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1m (3ft)...
£14.05
