StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector t...
StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad
£14.23
Colours:
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Complements your white Apple mobile devices
  • No incorrect way of plugging the connector into your mobile device
  • Guaranteed reliability, backed by StarTech.com 2-Year warranty
  • Length: 1m
  • Stock Status: In Stock
Product codes
Charge and Sync your Apple Lightning-equipped devices. The USBLT1MW 1m White Lightning to USB Cable for iPhone, iPod, and iPad provides a reliable solution for charging and syncing your newer generation Apple mobile devices with your PC or Mac computer, through an available USB port.
Plus, the reversible 8-pin Lightning connector can be plugged into your iOS-enabled device with either side facing up, meaning there is no wrong way of inserting the cable into the device.
This durable cable is Apple MFi certified.
If your computer USB port does not deliver sufficient power and you see a "Not Charging" message on your iPad or other Apple device, you can use this 1m Lightning to USB Cable with the USB 2.0 Fast Charging Adapter (USB2CHADP) in order to fast charge your devices.
Product Description StarTech.com 1m (3ft) White Apple 8-pin Lightning Connector to USB Cable for iPhone / iPod / iPad - Charge and Sync Cable - 1 meter (USBLT1MW) - Lightning cable - Lightning / USB - 1 m
Cable Lightning cable - Lightning / USB
Technology Double shielded
American Wire Gauge (AWG) 24/28
Length 1 m
Colour White
Connector Lightning - male
Connector (Second End) USB - male
Features Sync and charge
Designed For P/N: BOX4HDECP, BOX4HDECP2, MOD4AVHD, MOD4AVHDBT, MOD4DOCKACPD, ST43004UA, ST4300MINI, ST7C51224, ST7C51224EU, USB2PCARBK, USB2PCARBKS, USBLT2PCARW, USBUB2PCARB
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1m (3ft)...
£14.23
