StarTech.com 1m 3.3ft 40G QSFP+ DAC Cable
£113.92
13 in stock
Delivery:
Standard: 1-3 working days
Key features
  • 100% compatibility with HP JG326A guaranteed
  • StarTech.com SFP cables are backed by a lifetime warranty
  • Uses a cost-effective cabling alternative to fiber-optic setups
Product codes
Connect your HP 40GbE QSFP+ network devices with this cost-effective, passive Twinax copper cable. This 40G QSFP+ cable delivers what you need most in your network connections: reliable performance. It's built to MSA specifications and fully tested to ensure seamless compatibility.
This passive twinaxial cable is a fully hot-pluggable, direct-attach cable, supporting 40 Gigabit Ethernet applications connected through QSFP+ (Quad Small Form-Factor Pluggable) ports.
Designed for short-length, high-speed interconnects, this low-power, low-latency Twinax cable is a cost-effective alternative to fiber-optic cable assemblies, supporting short-distance applications such as point-to-point in-rack network switch or server connections.
StarTech.com HP JG326A Compatible QSFP+ DAC Twinax Cable - 1 m (3.3 ft.) - 40GBase direct attach cable - 1 m - black
40GBase direct attach cable - SFF-8436
Twinaxial
Passive cable
Length
1 m
Connector
QSFP+ - latched
Connector (Second End)
QSFP+ - latched
HP JG326A
2 years warranty
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1m 3.3ft...
£113.92
