StarTech.com 1m 3.3ft DisplayPort 1.4 Cable
£20.32
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • DISPLAYPORT 1.4 CABLE: VESA Certified w/32.4Gbps bandwidth; 8K 60Hz (7680x4320), 4K 120Hz (3840x2160), HDR for high contrast ratio, HBR3, 32 ch audio, MST for monitor daisy-chain, FEC error control
  • RELIABLE: Built with internal wire manager to ensure signal integrity; Metal connector sub-structure provides EMI shielding; Latching DP connectors prevent accidental disconnection
  • DURABLE: PVC jacket of this slim video cable absorbs stress of frequent bends protecting the core of the DisplayPort cord; Gold plated connectors prevent oxidization and tarnish, Lifetime Warranty
  • APPLICATIONS: Ideal for professional workstations w/Radeon Vega Frontier/Pro WX Series/W5500/Pro Duo & Nvidia Quadrop; Compatible w/DP 1.1/1.2/1.3 (1080p/4K) cards & adapters to future-proof for 8K
  • SPECS: 1 m 3 ft
  • Black
  • DisplayPort 1.4
  • DP Male to Male
  • 34 AWG
  • Jacket: PVC
  • EMI Shielding
  • Supported Protocols: HBR 3, 4:4:4 Chroma Subsampling, DSC 1.2, HDCP 2.2, MST
  • Lifetime Warranty
  • Type: DisplayPort
  • Length: 1m
  • Stock Status: In Stock
Product codes
This DisplayPort 1.4 cable lets you connect your DP laptop or desktop computer to an ultra-high definition 8K monitor, TV or projector.
The DP monitor cable provides the essential final link in your audio-video setups and is ideal for: Delivering enriched presentations; Displaying crisp digital signage walls; Creating eye-catching visuals for photography, videography, cinematography; Producing lifelike gaming.
This DP cable is VESA certified to ensure full compliance and efficient operation of the higher link rate of HBR3. It has been tested to meet all DP 1.4 specifications to ensure quality and reliability.
This 8K DisplayPort cable supports all DP 1.4 features: Resolutions up to 8K (7680x4320) @ 60Hz, backward compatible with 5K (5120x2880) @ 60Hz and 4K(4096x2160) @ 120Hz and previous generations of DP; High Bit Rate 3 (HBR3) bandwidths of 32.4Gbps; High Dynamic Range (HDR) for higher contrast ratio and vivid colors; Multi-Stream Transport (MST) for daisy-chaining multiple monitors; Display Stream Compression 1.2 (DSC); Forward Error Correction; 32 uncompressed digital audio channels; HDCP 2.2.
The cable has a thinner 34 AWG construction that allows for flexible installation with minimal clutter, which is perfect for offsite assignments. Each connector features latches that provide secure connections between your devices.
Product Description StarTech.com 1 m VESA Certified DisplayPort 1.4 Cable - 8K 60Hz HBR3 HDR - 3 ft Super UHD 4K 120Hz - DP to DP Slim Video Monitor Cord M/M - DisplayPort cable - 1 m
Type DisplayPort cable
Features 8K support, flexible, Ultra HD (8K) support, HBR3 support, maximum resolution 7680x4320 at 60Hz, HDR support, 32 uncompressed digital audio channels, Multi-Stream Transport
Length 1 m
Connector 20 pin DisplayPort - male - latched
Connector (Second End) 20 pin DisplayPort - male - latched
Compliant Standards DisplayPort 1.4
Colour Black
Designed For P/N: CDP2DPHD, CDP2DPVGA
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1m 3.3ft...
£20.32
