StarTech.com 1m 3ft USB 3.1 C to B Cable
£17.84
12 in stock
Delivery:
Standard: 1-3 working days
Product codes
Connect USB 3.1 or 3.0 USB-B devices to your USB-C host. Need to connect a new USB-C device to a USB-B device? This 1m USB-C to USB-B cable is the perfect solution. It's also compatible with Thunderbolt 3 ports.
With a bandwidth of 10 Gbps, this USB 3.1 Gen 2 cable lets you connect your USB-B devices such as hard drive enclosures and docks to your laptop, at speeds like never before. Now, you can spend less time transferring and backing up your data and more time focusing on your projects and presentations. USB 3.1 is twice the speed of USB 3.0 and 20x faster than USB 2.0.
Plus, the cable provides up to 3A for powering your devices, where supported.
You'll also be able to connect your older USB 3.0 peripheral devices to newer computers with data transfer speeds of up to 5 Gbps.
StarTech.com USB 3.1 USB-C to USB-B Cable - USB-C cable - 1 m
USB-C cable
Double shielded
Length
1 m
Connector
24 pin USB-C - male
Connector (Second End)
9 pin USB Type B - male
USB 3.1
Apple MacBook
Customer reviews
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1m 3ft US...
£17.84
