StarTech.com 1m DisplayPort 1.2 Cable with Latches M/M – Disp...
StarTech.com 1m DisplayPort 1.2 Cable with Latches M/M – DisplayPort 4k
£13.46
More than 50 in stock
Delivery:
Standard: 1-3 working days
  • Type: DisplayPort
  • Length: 1m
  • Stock Status: In Stock
Product codes
Create high-resolution 4k x 2k connections with HBR2 support between your DisplayPort -equipped devices. The DISPL1M 1m DisplayPort 1.2 Cable with latches provides a secure, connection between your DisplayPort-equipped devices and is capable of providing higher performance than either HDMI or dual link DVI.
The DP cable supports high resolutions of up to 4k x 2k (3840 x 2160) @ 60Hz with a maximum HBR2 bandwidth of 21.6 Gbps. The cable also supports Multi-Stream (MST) for daisy chaining multiple monitors and provides optional audio support.
Product Description StarTech.com 1m DisplayPort 1.2 Cable with Latches M/M DisplayPort 4k - DisplayPort cable - 1 m
Type DisplayPort cable
Technology Shielded
Features Latched
Length 1 m
Connector DisplayPort - male
Connector (Second End) DisplayPort - male
Compliant Standards RoHS
Colour Black
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1m Displa...
£13.46
