StarTech.com 1m Fiber Patch Cable LC - SC
£13.14
Hurry, only 1 left in stock!
Delivery:
Standard: 1-3 working days
Key features
  • Fiber Optic cables are an ultimate solution for high- speed data transmission;
  • Fiber optic cables provide a higher quality signal over a greater distance;
  • Does not carry electricity thereby avoiding the explosive consequences of a broken copper line;
  • Fiber optic cabling can maximize wiring conduit usage while minimizing installation problems.
  • Length: 1m
  • Stock Status: In Stock
Product codes
Connect fiber network devices for high-speed transfers with LSZH rated cable. The FIBLCSC1 1-meter (3.2ft) Multimode 62.5/125 Duplex Fiber Patch Cable is terminated with one LC (male) connector and one SC (male) connector, to provide the necessary connection between fiber networking devices for high-speed, long distance networks.
This LC-SC patch cable is housed in a LSZH (Low-Smoke, Zero-Halogen) flame retardant jacket, to ensure minimal smoke, toxicity and corrosion when exposed to high sources of heat, in the event of a fire. Making it ideal for use in industrial settings, central offices and schools, as well as residential settings where building codes are a consideration.
To ensure optimum performance, the multimode fiber duplex cable is individually tested and certified to be within acceptable optical insertion loss limits for guaranteed compatibility and 100% reliability.
The LC-SC Multimode Fiber Patch cable is guaranteed to provide long-lasting dependability, and top quality performance.
Product Description StarTech.com 1m Fiber Optic Cable - Multimode Duplex 62.5/125 - LSZH - LC/SC - OM1 - LC to SC Fiber Patch Cable (FIBLCSC1) - network cable - 1 m
Type Network cable
Technology Fibre optic
Type of Fibre Optics Multimode
Length 1 m
Core / Cladding Diameter 62.5 / 125 micron
Connector 2 x LC multi-mode - male
Connector (Second End) 2 x SC multi-mode - male
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1m Fiber...
£13.14
