StarTech.com 1m Gray Gigabit Snagless RJ45 UTP Cat6 Patch Cable
£3.44
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • High quality 24 AWG copper wire
  • ETL Verified
  • HIGH PERFORMANCE CAT6 ETHERNET CABLE: 100% copper for error-free Multi Gigabit 1/2.5/5Gbps connections; 10Gbps up to 50m; Fluke patch cord tested to comply w/ANSI/TIA-568-2.D Category 6 & ETL Verified
  • POE SUPPORT: 24 AWG stranded copper conductors & UL rated wiring supports up to 100W for PoE devices like VOIP phone & security systems; IEEE 802.3bt & DTE power compliance reduces cable heating
  • QUALITY CONSTRUCTION: ETL & UL certified wire; 50-micron gold-plated connectors prevent rust/corrosion to avoid costly network downtime; High quality PVC jacket resists bending or fraying damage
  • EASY INSTALLATION: Snagless patch cord for easy installation & flexible disconnection in wiring conduits; Compatible w/Cat5e & earlier standards; Molded boots available for constrained spaces
  • Length: 1m
  • Colour: Grey
  • Stock Status: In Stock
Product codes
StarTech.com Cat6 Snagless UTP patch cables are constructed with 24 gauge copper wire to support a broad range of Ethernet applications, such as Power over Ethernet (PoE), and feature specialized connector moldings that help prevent snags during cable runs. Because StarTech.com uses a high quality UL Listed 24 gauge insulated copper wire, its cables easily sustain the nominal voltage (48v) capability required for Power over Ethernet applications, whereas the inferior quality offered by copper-coated aluminum cables may be subject to insufficient power delivery, heat buildup and potentially equipment damage. All of StarTech.com Cat6 patch cables are wired to ANSI/TIA-568-B specifications.
Product Description StarTech.com 1m CAT6 Ethernet Cable - Grey Snagless Gigabit CAT 6 Wire - 100W PoE RJ45 UTP 650MHz Category 6 Network Patch Cord UL/TIA (N6PATC1MGR) - patch cable - 1 m - grey
Type Patch cable - CAT 6
Technology Unshielded twisted pair (UTP)
Wiring Scheme T568B
Features Snagless
Length 1 m
Connector RJ-45 - male
Connector (Second End) RJ-45 - male
Colour Grey
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1m Gray G...
£3.44
