StarTech.com 1m HDMI to DVI-D Cable - M/M
£8.74
More than 50 in stock
Delivery:
Standard: 1-3 working days
Key features
  • Reverse configurability/connectivity offers double the value of a normal HDMI®-DVI-D cable, enabling you to connect an HDMI-enabled output device to a DVI-D display, or a DVI-D output device to an HDMI-capable display
  • Ensures compatibility between two distinct digital video interfaces, for applications that require optimal levels of image clarity and quality
  • Saves money and reduces clutter by combining high-bandwidth video with digital audio connections in a single cable
  • Length: 1m
  • Stock Status: In Stock
Product codes
The HDDVIMM10M 10-meter HDMI to DVI-D cable enables you to connect a DVI-D video card (or other DVI-D output device) to a display that incorporates HDMI technology; the cable supports bi-directional operation that also allows the reverse configuration, delivering digital video from an HDMI-enabled output to a DVI-D capable display.
A valuable addition to any digital signage, multimedia or home theater application, this high performance cable is designed to provide the best quality picture available through either HDMI technology or DVI digital connections.
Product Description StarTech.com 1m HDMI to DVID Cable M/M - video cable - HDMI / DVI - 1 m
Cable Video cable - HDMI / DVI
Technology Shielded
American Wire Gauge (AWG) 28
Length 1 m
Colour Black
Connector HDMI - male
Connector (Second End) DVI-D - male
Accessories
Need it in a hurry?
Over 15,000 products
UK customer service
Over 25 years of experience
easy to use product image
StarTech.com 1m HDMI t...
£8.74
